bcarso
When I build stuff before the pcb stage I use solid tinned-copper buss wire, and teflon tubing where necessary. I love teflon because of the absence of carbonization and meltback. Once in a while for predominately digital stuff I'll use kynar wire-wrap wire and strip and solder it. In either case the joints are mechanically tight (woe if I have to change things though!) and the solder is not doing much to add mechanical strength---solder is not at all good for this.
Because of the nearly gas-tight connections before soldering, the solder connection length is really short. I've never measured or heard any effects associated with one brand etc. of solder over another, but the resistivity is higher than copper so the less involved in a connection the better---for example, putting a tiny component lead in a big PCB hole is a bad idea.
