Winston OBoogie
So,
I have a valve differential amplifier that is an output stage. It is directly coupled from another differential input stage.
The DC level at the anode/grid nodes is not constant and moves as part of a sensing system on the input stage grids. The change in voltage at these nodes might be 100V +/-.
My output stage must be able to drive a fixed load to full capacity at all times so I can't have appreciable changes in current.
Therefore, I have a constant current sink on the output stage cathodes.
Currently (!) the sink is a fairly simple high voltage cascoded MOSFET affair and is operating within safe limits. For the record, sometimes the changes in voltage I'm sensing may happen fairly quickly, although we're not talking uS. Rise/fall times of 1mS might be the fastest I'll encounter.
Anyway, I've been plowing through a few old Tektronix schematics for inspiration and I'm about convinced that I don't need anything more than what I have.
But, does anyone feel there would be benefit to another approach? Pentode sink? choke sink? Fixing the thing in treacle?
John
John
