timjimbaker
Member
- Joined
- Feb 10, 2010
- Messages
- 12
Hey guys... I modded a couple of modules from an old roberts 770 tube tape machine as per Rod C.'s instructions on beyondsanityproductions.com (Thanks Rod!). The first preamp works great. I am having a problem with the mic preamp section based around the EF86/6267 pentode in the second preamp...
http://www.beyondsanityproductions.com/misc/Akai%20M7%20Right%20Schematic%20_MOD_BorisModel.jpg
First, why is C3 connecting the screen grid to the cathode resistor(R6) and bypass cap (C2)? Should C3 be passing a voltage through to the cathode? My working pre is reading about 30VDC at the junction between C2 and C3 as opposed to 1.3VDC on the non-working unit. I am using new tubes, I've tried replacing components and i can't seem to get the second unit to pass signal. I am starting to think that maybe a small voltage (roughly 1.3VDC) is normal for the cathode... Any help explaining what's supposed to be happening in this circuit would be really appreciated. Best regards, Tim
