pucho812
What’s a good ef86 tube for mic use that won’t break the bank
I think that 20% reject rate is pretty good. Tubes have historically been selected for low noise and microphonics and I suspect their reject rate was no better. A decade ago I was using 6CG7 tubes in my mic pres. I purchased about 100 NOS samples and tested them all for noise and microphony. The reject rate was about 30% I then tested current production ones and found them to significantly better than that. All the testing I have done indicates that NOS tubes are generally worse than current production when it comes to noise and microphony.The current tube production quality is no longer what it used to be.
Recently, I have tested many tubes for a microphone company.
There were a lot of rejects because of a high self noise and microphonics.
Even some 'new' tubes, straight from the factory, didn't even work. (They showed a white ring on the top of the tube.)
I suppose this says a lot about quality control at the factory nowadays.
I ended up with a reject rate of about 20%...
It's true, you don't discard them for noise or microphonics, but due to the 'eq curve' they each have, to suit the voice you make the microphone for.. Valvo ones are very good as well, and PF86 as well, the mazdas/philips etc are great for preamps, they don't really have a sound, but you can find TFK ones for less than 20e easily!IMO, the best EF86 is a TFK version with a nickel plate, and can still be found on ebay for 15-20 Euros or less. None of the ones I bought when I needed them were discarded due to excessive noise or microphonics. All of today’s productions are a waste of money and time for me.
Application is replacing a dead tube in a vintage u67Depends on applikation. If youre flexible with heating, then PF86 are still available at good price/quality.
Valvo is clean and natural, Telefunken silver anode is more open but very nice, TFK EF806s is warm and round, extra low end ,and less highs than the silver version.Application is replacing a dead tube in a vintage u67
