The best T4 I own has Radio Shack LDR cells and an EL panel out of an alarm clock.
But, I do not know how long the panel will last. The alarm clock panel is only meant to be switched on a few minutes a day, so ....
On the other hand, a nite light burns 24/7.
Go into your nearest Rite Aid or Wallgreens and see if you can find a clock or nite light with a panel. Be warned, with the advent of blue LED's, the Chinese are finding the LED to be much more cost effective than a phophorous panel and inverter circuitry. In other words, clocks that once used the EL panel no longer have the panel even though they look the same as last years model. I found this out the hard way. Make sure it says EL on the package. I even found one nite light that had a replacement panel that you could send away for. Since the lite cost 7 bucks, the panel was probably half that. But when I went back to get the web site off the lite package, it was gone! Never to be seen again. I was so close to finding a cheap replacement. If you see something good, snag it. Don't wait. This goes for guitars, girls, cars, been burned so many times by hesitating.
I will keep looking.
