Ela-M 251 Body from Aliexpress
Also, there was some discussion in other threads with the 6s6b tube in an M251 circuit, about the R1 plate resistor.
Is it best to work off the 200k value like the ac701 schematic? or stick with the 100k like the 6072a schematic?
What is the 6s6b closest to?
Yes sorry i was busy drawing the new schematic and i didn't see all the comments and your schematic Sparklebear thank you so much. C3 (10,000 pf) there just to filter noise off of the rail? Different than the role of c6 (600pf) in the m49 to shunt HF from plate out (to reduce hf response) yes? I got it now! Thank you all. Best
Where does the capsule get the polarization from? What's the voltage applied to it?
I didn't check the voltage! the Jules Op microphone can be use with or without dc hex inverter. the amp circuit is meant to work with an electret capsule. To my surprise the C12 cap was sounding pretty well without the dc hex inverter...
I'll measure mine and let you know. I have a sneaking suspicion they are very similar though.
Thanks Paul, yup, going by eye and the pics in the forum here I’m betting it’s the same body finished a little differently.
My capsules have shipped so I’m now just waiting on a PCB restock.
Beeznees, Danny just restocked the D251 boards so I’m more or less set.
Thanks Jim. I’m helping a friend who’s new to diy build up an 1176 and he’s got the bug, so would really like to build one of these mics. I’m trying to compile ‘a kit’ that would be reasonably ‘plug and play’ so with all the capsule options, it’s useful to know. I was going to suggest the BZ as that seems to be a popular choice, but tbh, I don’t have a benchmark.
Those aliex bodies look great, so that’s that sorted and I’m aware of the mechanical mods needed for Danny’s pcb. Was going to suggest nodding the Thomann retro psu to speed things up.
Reg, the BZ capsule, is the supplied mount useable or too big for the body?
Is it just a case of stripping down a 7 pin male XlR plug to use the connector part for the body?
Any help would be gratefully received and look forward to seeing your progress.
Chris
Hi @chrispbass
I'm standing on the shoulders of giants here but...
Some links here for you.
7 pin insert
https://www.aliexpress.com/item/100...o.order_list.order_list_main.5.4e521802A25s4c
Capsule holder (I thinkg the BN one will be too big)
https://www.aliexpress.com/item/100....order_list.order_list_main.10.4e521802A25s4c
Shockmount (these are ok, I might replace with the Rycote USM)
https://www.aliexpress.com/item/100....order_list.order_list_main.12.4e521802A25s4c
Washers to extend body (the inner diameter of the mic body is 49mm so I'm hopeful these will work, plus being conductive they'll help with shielding), I ordered 4.
https://www.ebay.co.uk/itm/294067528860?var=592756403381
If you hit me up with an email I can send you my BOM and some tuning notes gleaned from the build thread and other places. There are minor parts changes from Dany's BOM and I've ordered some alternative values for key components.
The relays are out of stock but I got the same part from Futurlec.
Hi @chrispbass
7 pin insert
You’re a star Jim…thank you. I’ve been gleaning as much info from the thread as I can, but that would be great. I’ll Pm you later (y)
These look great in person, much more cream coloured than yellow. Nicely finished and heavy.
If anyone can chime in and suggest how these dimensions might compare to the other version and the fit of the D251 pcbs that would be great, @HerbertR ?
Dimensions
Inner rails Length 124.5mm
Distance between outer edge of rails 40.5mm
Distance between screw holes 26.8mm
Body tube
Outer diameter 49mm
Inner diameter 43.65mm
Length 135mm
Headbasket
Length 65mm
Diameter front to back 50.8mm
Diameter side to side 50.8mm
Sorry, I did not read your post. Here are the measuments for a comparison
Post in thread 'Ela-M 251 Body from Aliexpress' https://groupdiy.com/threads/ela-m-251-body-from-aliexpress.84513/post-1097464
I think they are the same size....
The Beesneez capsule holder can be mounted directly in the microphone. It fits. Inside it is close to the top of the basket but offers enough space.
It becomes more difficult to optimize the mic for as little noise as possible. As easy as this microphone appears to be to build, a lot of optimization was necessary to make it quieter imo. Very good Tube, higher Grid to Ground Resistorvalue,...
