Electro Harmonix 12AY7 Mic Preamp - output capacitor selection?
tonedude
Sweden
I would like to upgrade capacitors C5 and C8 in the EH 12ay7 preamp but wounder what brand and type to select?
I guess it should be specified for a minimum of 200volt, or preferable 250volt ?, any suggestions for a high voltage 47uF cap in this type of audio application?
Offhand, I'd say between a 330K pull-down and a 220K internal load (plus whatever is on the end of the cable), it hardly matters what cap you use. Resistance dominates.
This is far enough away from most designs that I don't think anybody has experience.
Put in whatever caps you think will be better.
tonedude said:
They are not correct in the schematic above, "un-modded" they are 33k in that circuit. Mine is unmodded.
http://www.labjc.com/?p=966
33K is a much more sensible value. At least the output tube will be working in a sensible part of its characteristic.
In that case there really is little if anything to be gained by changing the output capacitor. Its value is so high that when feeding a regular 10K load its impedance is negligible and hence also its effect on the signal will be negligible. I recommend you check out the section on coupling capacitors in Doug Self's book.
Epcos, Panasonic, Nichicon, Rubycon are brands I would prefer in this position.  C5 and C8 should be rated for 250VDC, for 105 degC if possible. I will suggest you also to replace HT power supply capacitors with 47u/350V verisons. Be aware of limited space inside the box. And stronger (current wise) wall wart would be a good investment.
I hope you already  read JCM's posts on Tape Op and GL threads.
