clintrubber
Gert said:Maybe something like this will work: http://sound.westhost.com/project21.htm
Related stuff, but not frequency selective, like the discussed spreader is. But could be made to do so tough.
abbey road d enfer said:I believe Michael Gerzon and Alan Blumlein had a predilection for phase-shifters, which probably explains why these circuits were used in audio applications, when in other parts of the world, they were strictly for scientific applications.
Strawtles said:Right now I had confirm that the TG12434 is the same circuit of the TG12416 with less components
It seems that this circuit is really complex (two boards with a lot of components)
noulou said:I've got one unit here. Tg12416 V.A.L. module. When i get the time, i'd love to help.
Strawtles said:Thank you Noulou
How it sounds?
ed rees said:I'll explain how the passive spreader control in the REDDs worked. Maybe someone can design a spreader from this info?
The left and right mics go through a pair of S&D transformers.
Then the sum and difference lines each has it's own bridged T fader.
This is followed by the spreader, which is just another set of bridged T attenuators connected to work inversely.
After this is the shuffler, which would be desirable and was probably included in the TG unit.
Then the signals go through another set of S&D transformers to make them back into Left and Right signals.
For the shuffler, this looks like a 600 ohm version, no idea what it's from but it has the same topology as the Redd.17's 200 ohm shuffler.
http://www.richardbrice.net/EMI_shuffler_circuit.GIF
I believe it's time to take some distance with the guts and consider the usefulness of these gizmos.Lee_M said:ed rees said:I'll explain how the passive spreader control in the REDDs worked. Maybe someone can design a spreader from this info?
I know this thread is pretty darn old, But I read this post and realised the REDD passive spreader sounds like a very similar design to the passive "width" control in the BBC MX1/8 mixer.
The schematic and circuit description are in the attached PDF.
I'm in the middle of building the BBC width control to use as an external unit, But had been struggling to make sense of the "differential fader" mentioned in the PDF.
Inverted Bridged-T attenuators sound like a good plan for this. Thanks! ;D
I'm not sure what alternative transformers you could use for DIYing it, The only reason I discovered the deisgn was because I had some of those BBC transformers on hand and was trying to find their intended use.
All I can tell you is that they have 1 primary and 4 secondaries, Although that's obvious from the schematic. I guess I should have done some basic measurements on them before I wired them up...
abbey road d enfer said:I believe it's time to take some distance with the guts and consider the usefulness of these gizmos.
IMO, there is no doubt about the usefulness of the "spreader", which is basically a width control.
That can be implemented in M/S mode, with the added flexibility of inserting an EQ in the S path, which would allow controlling what frequencies are narrowed or spread. A much simpler implementation uses two opamps and a bunch of resistors and caps, doing the essential bits of the concept: narrowing bass and spreading treble.
But regarding the shuffler, I don't see any evident justification; indeed, in the preliminary, this has been designed to emulate the x-talk behaviour of phono cartridges, which apparently had some specific euphony.
I believe the main point is that it correlates surface noise, which makes it less apparent by about 3dB.
It turned out that the shuffler had also the virtue of centering the noticeable fact that many Beatles (and others) had e.g. drums and guitars on one channel , and vocals and guitar solo on the other , which was at some time quite disturbing.
I never figured that out when I was a kid, since I had a mono set, but it came eerily apparent when I was in a restaurant in Elkhart, where they had only one speaker per room.
Today, I don't see any serious justification for the use of such a device. There are pan-pots on every channel, and any DAW offers the possibility of duplicating tracks, inverting polarity and adding EQ.
Honestly no, because I had never heard or read about this before. So at the moment, the only evidence I have is that given on the phaedrus.com site.Lee_M said:What you said about phono crosstalk having euphonic properties sounds very interesting, Can you direct me to any links where I can read more on this?
Indeed, narrowing the stereo image at HF reduces the audibility of surface noise. That may be the only objectively demonstrable benefit.I had a look on google for more info but pretty much every result I found is about reducing or eliminating phono cartridge crosstalk.
Not new, though. M/S #101 being manipulating the relative levels of S and M, adding EQ is M/S#102.I think you may have just inadvertently added fuel to the DIY fire with your comment about adding EQ to the "S" path,
Beware that a passive MS matrix may be sensitive to input/output impedances.I've got a few odd BBC inductors lying around, So I guess some passive EQ bands could work nicely in this.
I've got a very minimal understanding of phono technology, Despite my love of it, But I guess this is the same principle as why the mono/stereo switch on my old sony TA-70 helps drastically reduce surface noise when set to "mono" for mono vinyl.abbey road d enfer said:narrowing the stereo image at HF reduces the audibility of surface noise. That may be the only objectively demonstrable benefit.
Looks like I'll be eating those words!Lee_M said:Plus it seems a bit more interesting than simply building another EQ.
Where can I study the full course? ;Dabbey road d enfer said:M/S #101 being manipulating the relative levels of S and M, adding EQ is M/S#102.
