correct url is http://www.phaedrus-audio.com/Lee_M said:Thanks for taking the time to help, It's greatly appreciated.
It seems that phaedrus.com site is no longer a registered domain and the wayback machine isn't getting me to any of the older pages.
Don't assume too much about British audio technology.I was just getting around to puzzling over the impedances, I'm still trying to understand how they are worked out so please correct me if I'm wrong!
Being a BBC unit, I'd assume its specced for 600R source and load...
Indeed.But I'm guessing this could be different as it's designed to be used within a mixer.
The issues here are twofold:The 1k2 resistors are making me question this too, Is there some kind of parallel relationship happening with them (and/or other components) which brings it down to 600R or is it simply working at a different impedance altogether?
First, the impedance on on side depends on the impedance on the other side. That's a consequence of the passive nature of transformers; energy is conserved from one side to the other.
Second, the impedance varies after the degree of correlation between signals. This is a tad more difficult to explain, but just consider the fact that when driven in mono (L=R), there is no signal in the S path. With a unitary system, the impedances are fairly constant, but as soon as the relative balance of M and S is altered, the impedance will vary as a function of correlation. Hence the need for low source impedance and high input impedance. [/quote]
I'm intending to mainly use this as a 2-bus processor, On the main inserts on my mixer.
The inserts are fully balanced (electronically) with a 20R output impedance and 20k input impedance.
Should I be thinking about termination on the i/o connections of this unit or is that not a concern? [/quote] I don't hink you need to worry about it.
T-pads are not a necessity herre; in fact you should really start with the notion that the source impedance is low and the input impedance is high, so the xfmrs and pads work in voltage mode.Thinking about it a bit more, I'll definitely need to work out the ratio that these transformers are wired for so that I can get my T-pad values correct.
I'm guessing there is a very slight increase in impedance from the first stage of transformers (Going by the 1k8 resistors at the M/S connections, either side of the fader) Which is then cancelled out by the second stage of reverse-connected transformers after the differential fader.
Am I on the right track? I wouldn't want to rely on this analysis, but seeing how it is interconnected with the "trolley", it looks like it operates in a 600 ohms environment and the faders are probably also 600r. The RC circuit would provide a 2dB lift at 20kHz in order to compensate HF losses due to the xfmr's leakage inductance.No, on the contrary.Is installing a buffer circuit in the "S" channel likely to cause undesirable phase issues with the M/S to L/R decoding?Indeed, it is feasible. But as soon as you enter the realm of active electronics, you will find that an active MS matrix has just about zero issues with impedance, frequency response or losses.I'm thinking a way around any potential issues or discrepancies produced by adding circuitry to just one channel could be to add the same active circuit to both channels but have the "M" channel with a resistive pad equivalent to the losses of the LC circuit (with an amplifier for makeup on each channel) and only actually include the LC components in the "S" channel. Does that sound feasible?
