pinebox
- Joined
- Mar 11, 2015
- Messages
- 142
Looks like I have an EMT 140st plate with a bad transducer on it. One side works, the other is dead, and when I swap the contact return connectors on the back of the amp side to side the dead channel switches. I need to check the amp out 100% before doing this because there are 6 or 7 of them in a cramped room with only 10" between each so it would quite a project making room to get the sides off, and a lot of them stay in use every day. This brings me to my questions:
1: What is the name of the connector that comes back to the amp from the contact mics? I could test the return amp by making a new cable with one of these and simply feed it mic level signal, but I have no idea what this connector is called and the documents I have only refer to the Tuchel connector by name. This would simply be to triple check my troubleshooting, I am 90% sure I lost the contact mic.
2: How delicate are these microphone contact mounts to vibration? I suddenly have two separate 140st side go out on one side and the only thing I can think of is there was an earthquake recently, around the same time it was noticed. Is it feasible they could have fallen away from the plate?
Thank you.
Thank you.
