Trench Recordings
I emailed Peter. He has a few available now and another batch coming
The fix is to just jumper the green wire in the JRowell's photo a ways back. This is what I did and mine have been working great for a while.Rob Flinn said:On the droop fix, I understand that a wire needs to be connected in the green position. What is the red wire on the photo ? Is that something to ignore, or does a trace need cutting ?
weiss said:Got some in stock again?
Trench Recordings said:Anyone know the part number for the 1MM pin sockets ? I'm missing 10 and need to order.
I tried some from CAPI but they are too large dia. to fit in the PCB.
Looks like i might a Harwin ? and not mil-max
Edit* - Thanks Peter
Newark/Farnell part numbers...
Pins 1336227
Skts 149-318
late said:Anyone knows where to get good looking knobs? Would like to get bit original look.
mysticmerlin said:The website for lazpro has gone down and I was just about to finish 4 eqn's . Would anyone have a schematic or something similar (build notes/ calibration guide / Bom) to help me finish?
corgan4321 said:Hello,
I'm sorry for resurrecting an old build thread but I've just finished building a pair of EQNs and am having the same problem with both. I'm able to properly bias them with my scope but at the point of equal clipping, I'm getting low frequency oscillating and motorboating that changes with the location of RV5. By turning it CCW or CW the pitch of the oscillation changes. I'm able to get rid of this oscillation and noise if I turn RV5 CCW, but when I do so, the bias is all wrong and I get unequal clipping of a sine wave thru the unit. I'm in a Radial 500 series rackmount and when I unplug all other units, I still get the same problem.
All the controls of the EQ work great besides this unwanted noise and oscillation. I've double checked my transformer wiring and the resistor values around the output stage on the main boards and all seems well.
I would greatly appreciate any direction, thank you!
