Hi Everyone,
I am in the process of completing two EQP 1-A Pultech-style equalizers. One seems to work ok, and the other does not. I have narrowed it down to a voltage issue on the 12ax7 tube, specifically with pin one. The reading on pins one and six should be 140 volts +/- 10%. Pin six is good, pin one isn't, and I am at a loss on where to troubleshoot next. I have changed the base, confirmed the tube is good and doubled checked the wiring against the good unit and made sure there are no shorts etc.. I have posted a pic of my readings. Any guidance would be greatly appreciated as I am on day three and at my wit's end.
