Deepdark
ruffrecords said:The inductor has a wider range than the original so you will need to alter the frequencies if you want the same Q curves as the original but otherwise there are no changes to make.Deepdark said:quick one. i want to replace the 7 position highs with a 6 positions. with a inductor of 269/169/69/22, and a 2k2(2k5??) high Q pot, is there something else i should change,or the filter section remain the same?
looking at individuals inductors, mouser stock a lot of them. is there some manufacturer they are Worth looking for? API Delevan, Hammond, Fastron, Murata, etc. I looked at Cinemag and Carnhill to know if they have/could make them. I know Sowter stock them, by the way.
Sorry, no experience of inductors for original design.
Individualy, the inductors values are 100mh, 100mh, 47mh, 22mh. So in series it gives the values i wrote. What do you say by i need to alterate the frequency to get the same curve as originaly? Do you mean replacing certain cap values? There is a couple of caps values who changed, probably to keep the curve as close as possible to the original filter curve. I follow the gpultec filter schematic to do that mod.
