[quote author="kiira"]
http://www.2tough.com/~kiira/rec/1626.pdf
[/quote]
Oooh, grid current for 5 W triode, somewhat unusual...
For audio grid current is used for 1 kW + power, because
efficiency is higher.
But really. This is tube intended (only hypothesis ????) for solo - oscilator transmitter,
then grid current was used (with grid bias resistor) to stabilize
amplitude of the oscillator (still working in linear region).
But you use triode as resistor coupled amp? why. If you use
pentode with the some transconductancy, you will have gain 5 X
higher.
Triode is unpractical in resistance coupling, mainly because inner resistance dominates and decrease gain.
In all causes, you will be still in the grid-cathode negative voltage
region without grid current. Icat = I plat.
By the way. It is relative big triode, and 1 M grid - leak resistance
can be too much. See similar circuits, or measure R1 voltage drop.
May be under 100 mV. If not, use resistor 100k or lower.
xvlk
