Oscillation. Feedback gain greater than 1What do you mean by "runs away" ?
Seems it would be not much different to applying the feedback externally (maybe via aux send and a 2nd mixer channel)?The signal is picked up right before the last resistor of the circuit and re-injected right after the first resistor and the first capacitor before it enter the first opamp.
I think the proposed solution is flawed, for the reasons I exposed before. I understand they proposed it because it is easy to implement.Actually it seems that it s what was intended by Eventide back in the days (see picture from the user manual).
But what you are explaining here is interesting ! I guess both ways could be implemented at the same time with a switch to select one or the other.
You won't get a better quality schematic than that, it's hand drawn in the service manualL´Andratté -> It might be the same if there is no input and output trans installed, because the signal is taken before the output trans and re-injected after the input trans. It was an option. Mine doesn't have trans.
abbey road d enfer -> I don't want to say something completely wrong but from my understanding of the circuit there is no feedback involved.
The signal is processed through a first BBD chip (MN3001), from there it split in two different path, one is mixed with the original signal (which went through two all pass filters) and goes to the "auxiliary output", the other one goes through a second BBD ship for more delay and then get mixed with the "original" signal which went through four all pass filters at this point and goes to the main output.
About VR1, VR2 and R2, yes, it seems like they are. VR2 being a small trimmer installed inside the gear and VR1 the control knob on the face of the unit.
I attach the (very poor quality) schematic if you want to take a look. All the bottom part is for the generation of the clock signal sent to the BBD chips.
Thanks, it’s good to know !You won't get a better quality schematic than that, it's hand drawn in the service manual
