Eventide Instant PWM Phaser
Thanks Stephen,
That must have taken a bit of time to draw out!
Thanks again for the other schems in the other threads too,
:guinness: :sam:
Mark
Yes, a lot of time over about a month. I wanted to see the complete magnitude of the circuit because in the manual it states things like -"section repeated 6 times" so its difficult to visualise the complete works. I drew it up in Excel as that's what I've always used, and it looks good printed.
Stephen
This is really nice work Stephen, Thank-you! :guinness:
Have you tested the schem yet? I'm definitely interested in building one of these creatures, one can never have enough phasers - you've got to love an analogue phaser :thumb:
A couple of suggestions for phasers: Has anyone ever seen a schem for the AMS analogue phaser? That's one I've been after for years.
Also, is anyone here aware of the (Buchla I believe) "Barber Pole" phasers? I'm not sure phaser is the correct description for them, but I'd love to hear info from anyone that knows the device.
Justin
[quote author="thermionic"]Also, is anyone here aware of the (Buchla I believe) "Barber Pole" phasers? I'm not sure phaser is the correct description for them, but I'd love to hear info from anyone that knows the device.
[/quote]
The US-Patent # 04399326 gives a good overview about barberpole phasing. It's basically a Frequency Shifter that runs with very low modulation frequency (LFO range), plus some extra (fixed) all pass filters in the signal path and/or feedback path.
I have never played the Buchla, but I imagine there are a lot of possible combinations of these three parts, fixed APFs, variable APFs (like in ordinary phasers) and the frequency-shifter core which make musical sense, and from the looks of it, the Buchla seems to be a very luxurious variation of this.
If you want to experiment with this, just build the separate blocks and try different combinations. I'm not sure about this, but I think you won't even need the usual precision of frequency shifters for that kind of applications (no audio range modulators that would bleed thru!), but then again creating deep notches might also require some precision.
You might want to try this:
http://www.oldcrows.net/~jhaible/tonline_stuff/hj_fs.html
and combine it with various all pass filters according to the Bode patent.
JH.
[quote author="StephenGiles"]Once again I present to you.....Screaming...........Lord........no, wrong.....
http://img78.photobucket.com/albums/v317/StephenGiles/EVph_comb.gif
......whole works![/quote]
Hi Stephen,
the circuit looks impressive, and I find some very familiar (from the Flanger) building blocks in there.
Is your drawing more or less how Eventide built it, or is it a variation of your own? (I was very surprised to see a PWM method used in here, I would never have guessed this from these pictures:
http://www.modezero.com/instant_phaser.htm )
JH.
Thanks for those links JH :guinness: A pal of mine owns a Buchla barber-pole unit, you wouldn't even want to think about what it cost... If I remember correctly, they swore him to secrecy when they sold it to him, so I can't see him letting me look under the hood without a fight (not that I'd find anything, I bet it's potted).
If anyone's got the spare moolah check this link: http://www.buchla.com/200e/index.html
BTW, Stephen, slightly OT, but an interesting thread re: thru-zero flanging came up at Fletcher's forum: http://recforums.prosoundweb.com/index.php/t/1950/0 Check Steve Albini's comments.
Justin
