> getting the right person ... took it pretty seriously.
Yes. It IS a serious issue. Depending where the current flows, you can have dead dogs, dead water-meter men, or even dead customers. And current leaking before a customer's meter is unprofitable!
NYC had a few cases recently, dogs shocked from stepping on manhole plates. The Jersey Shore had a situation a few years back, a whole neighborhood was getting shocks and it took a long time for the electric company to find the fault.
I have heard of ground leaks so bad the snow melted all around the ground-rod.
> the neighborhood neutral looks bad.
That's a nastier problem than I expected. I don't know much about underground distribution. Do they just bury the standard overhead cable, two insulated wrapped with bare? In our area, that's begging for wire-rot. When the bare neutral rots-out, you have 240V split across whatever balance of loads you have on each 120V leg. Since your 120V loads "never" balance, a difference current flows. It can't return to transformer CT, so it flows to ground and eventual balance with the entire utility system.
> a copper pipe* from my furnace to the AC unit outside
Probably freon, not water; and that really should NOT be a current path. The furnace shell is bonded to fusebox ground. The outside compressor is bonded to fusebox ground. And you don't bond with water-pipe, much less a freon pipe. There should be ground wires (or conduit). So there should be zero voltage between them. And no current in the pipe.
> my AC pops the circuit breaker so frequently
There may be multiple problems.
It's your space, your butt. Be careful, but be curious. If you feel comfortable opening junction boxes and fusebox, look and follow the groundING conductors. These are bare or green wires. Almost every post-1961 circuit "must" have one. You should be able to follow Ground from fusebox all the way to the load. No breaks, no loose or tarnished connections. Conduit and armor-cable connectors are often untrustworthy; I try to specify a wire-ground be run in conduit.
I think grounding has been required for furnaces and 230V loads even longer. The last major "ungrounded" circuit is a legacy electric stove (and maybe dryer?): these used to be allowed "ground through Neutral" because the nominal Neutral current is small. New stove circuits are supposed to be 4-wire H-H-N-G, but an old 3-wire in good shape may stay in service.
