Hello Jano1954,
It is a text book generic design. The values depend on how you want to configure it. However, C7 and C8 are rail supply by-pass and 100nF is a standard value..
Both sides are identical. So, take the left hand side.
Say, to unbalance the input before the fader.
Keep R1, R7 and R3, R5 the same for unity gain. 10k.
C3, C5 27pF to 47pF. Or whatever in between.
C9, C11 are input coupling. Look up RC cut off frequency calculator on the net. 47uF will give you a lower cut off frequency of less than 1Hz. Footprint is 10mm in diameter. Plenty of space to put in anything you have in your parts box.
C1 is the output coupling. So, again you are driving into 10k fader and 47uF is plenty. R9 is normally there to keep the output at ground level and also to discharge the output cap when not in use. But as you have the fader you do not need to use it.
Now, there are hundreds and hundreds of circuit examples in the Technical forum that you can adapt this board to by lifting the values straight from them. Check for example, Amek, BSS, Soundcraft, anything really. It will be good for learning. In fact the component values I gave you up there will come up in most of them.
