Che_Guitarra
The name of the pedal is a mouthful; Catalinbread Pareidolia Harmonic Mesmerizer.
Having owned one in the past, I know I have an output problem. Or more accurately, a lack of output volume.
Engaged, with the output control fully dimed, I can barely reach parity with the bypass signal. I remember parity being closer to 12 o'clock on the dial. On this unit, 12 o'clock on the dial is but a whisper. The only good news is the fact i is passing signal. The other controls seem to be working fine.
Looking at the PCB, the solder peaks around the ICs are not the prettiest. That said, I can't see any obvious faults either. No solder bridges, no cold solder cracks, and trace continuity appears fine. I'm yet to pull the PCB from the enclosure for full circuit inspection.
I've contacted Catalinbread but no reply as of yet.
So... good folks of Group DIY... I'm hoping you can help me troubleshoot this problem. I'm guessing i'm bleeding signal to ground where I shouldn't be, or i'm not bleeding to ground where I should to be. But my electronic insight ends there.
Where to start with diagnosing a fault like this?
