Favorite preferred program for creating schematics ?
Winnipeg Mb Canada
I may have asked before but still need  a program to make schematics
what is anyone here using & like ?
P.S. doesn't have to work in THIS new format
I use Eagle. It's fast and stable, and I am way quicker with it than with any other program I've used. I really enjoy using it very much. If you only want to draw schematics, there is no downside with using the free version.
I was borderline ready to accuse you of trolling!
Eagle. Some folks are moving to KiCad now that CERN are funding it. However, once you master the Eagle interface, you attain Jedi status. I keep a number of scripts that I use for generating pdf's, hiding labels and zooming to any unrouted wires. Fairly awesome stuff.
/R
I don't intend or expect to  do anything complex, just
A]  make nicer than hand drawn schematics to save on the computer
B] maybe have the ability to easily & cheaply make the odd pcb
thanks for the replies so far
What about multisim blue? I downloaded it but I didn't have the time to try it out, should be very alike multisim I guess which I like it, but now is free. And if you are ordering from mouser you have one less step to do so! I can't use that feature here in Arg but still... I used Eagle and have most my projects there, but is much easier to make a simulation in  multisim, those virtual instruments are quite good for fast and simple simulations, and then you have all the usual spice stuff there. I guess multisim blue still have all that stuff.
JS
I was referring to the online digikey type version, where a friend lost his work, not like a local computer
crash but the mercy of the interweb!
Been use labcenters proteus and it works well. Then I moved into the new gig and here we use altium designer.  At a 7000.00  license for Altium I wouldn't suggest it but proteus has done me well and I know others who use it with much success.
I am long past the point of being willing to learn a whole new set of secret handshakes. So as long as I can make serviceable designs with Eagle I will keep using it. I wouldn't mind better (smaller) design rule limits, but don't do that many boards for it to matter.
I do not defend Eagle I had to use it to service a design  over a decade ago when I was supporting a friends DSP product. I got a free eagle chair in connection with that consulting and am still using it while it is getting long in the tooth (not the newest version of Eagle)..
I went for Diptrace as the user interface is much more adequate then Eagle. I tried KiCad, but at an earlier stage at least I did not find it very intuitive. Diptrace has a lot less parts in the libraries, but you can fairly easily import eagle libraries into Diptrace, so not a real problem.
Eagle's 80 by 100mm (free use) limitation was unreasonable, but I quickly ran out of Pins (Diptrace free use limit) so I ha do bite the bullet an buy a license. I have not regretted it...
- Michael
