Bonsaimaster
- Joined
- Apr 17, 2013
- Messages
- 218
Dear Friends,
I am inheriting a Federal AM 864/U limiter. I think it is in good condition. I am looking to make modifications to the unit. I have searched all the threads but still a bit confused. Therefore, I am ask you all to help with the information I have obtained. Maybe this will be a resource to others trying to do their own modifications. I am going to try to keep the modifications compartmentalized as this may be easier to follow. Please correct or enlighten me on any of these modifications. I will keep updating the post with the new information.
1) INPUT ATTENUATOR
Replace the 500k linear pot with a 500k log pot.
2) INPUT ADDITION
Add a 30dB "H" pad before 600 Ohm input
3) ADD ATTACK CONTROL
Replace R11 (47k) with 25K log pot and 22k resistor in series
(Are there any suggestions for a stepped switch? resistor values? or just a 12 step linear switch?)
4) ADD RELEASE CONTROL
1 Meg log pot in series with R1
5) METER ZERO
Add 500 ohm in series with R12 (1.8k)
Place on back of unit
6) ADD OUTPUT
1k Log Pot as part of the H-pad
7) THRESHOLD LIMITER (RATIO)
Replace 500k pot with 100 K log pot plus a 400K resistor in series
Move to front of unit
8) CURRENT CONTROL (THRESHOLD)
Replace 1k pot with 1k log pot with a 1k3 resistor strapped across legs 1 and 3. (resulting in ~ 600 R total resistance).
(Are there any suggestions for a stepped switch? resistor values? and corresponding ratio values?)
8) Things I am not sure about
-Disconnect jumpers for LO 600 Ohm input (Not sure what jumpers for LO 600 ohm input mean. Necessary? )
-Place a 680 Ohm resistor across output terminals (Do I do this if adding the H-pad ?)
Thank you for being patient with me. There maybe some misunderstanding but this is what I have deduced by reading the forum posts. If there are any other suggests please share.
Bonsaimaster
1) INPUT ATTENUATOR
2) INPUT ADDITION
5) METER ZERO
6) ADD OUTPUT
Bonsaimaster
