[quote author="SUPERMAGOO"]is the feedback connection for tubes realy necessary?. is it for correcting fase only or does it have another function?[/quote]
It depends on how you define "necessary". It's possible to build excellent circuits (such as preamps) using feedback connections around tubes. It's also possible to build excellent circuits without using feedback, if you design the circuit to operate that way. Removing the feedback from a circuit that is designed to use it will usually not produce good results.
It has other functions besides correcting phase (which it doesn't always do). Well-designed feedback can lower the distortion level of a circuit, allow it to be less sensitive to changes in the tubes' characteristics with age, and/or tailor frequency response in a desired way. Some forms of feedback also lower the output impedance of a circuit.
In short, feedback can be one of many useful tools for the designer; you can design with it, or without it, but simply removing it from a circuit is usually not a good idea.
Peace,
Paul
