GssL 20th Anniversary edition
Don't be confused. I'll explain:
- BOMs and Reichelt Part Lists should be updated by now.
- the referenced Corrections "Rev 3 needs following..." need to be applied. It's in the blend Circuit as outlined, and the wrong part is in Side chain HP switch.
Let me know if i can assist you..
I'm still a bit confused about the errata
The errate under this header is not relevant to the rev 3 board.
Errata to make the test run board perfect
Its just left there to the handful of people who are building the test board...
...and none of it will make a difference between a unit just blowing up or not. If it did, it wouldve been posted in bold and repeated 20 times.
Gustav
@Gustav Are you aware of any other switches that could directly work on the switch pcbs? I was thinking of maybe using some grayhills and wire them.
There is something about the feel of the lorlins that I really don't enjoy
Sorry, I dont know of a switch that shares the exact footprint.
I also happen to think the Lorlins are great for most applications - including this one :) Of course, you can wire up anything you like, how you like, which is the great thing about DIY.
Gustav
