no I grounded the pins of the XLR to the board and grounded the separate chassis pin on the XLR to chassis.
sr1200 said:no I grounded the pins of the XLR to the board and grounded the separate chassis pin on the XLR to chassis.
sr1200 said:If you start cranking the gain to +60 theres noise on it, but the neve desk i used years ago had about the same "hiss" to it when it was cranked.
mulletchuck said:Ninuz, draw a schematic of how you have it wired on a piece of paper and post it.
Slenderchap said:That is correct for 220/240v operation..... it should only take about 15mA from the mains so a 100mA Slow Blow should be OK
Do you have a bench power supply with current limiting outputs ?
If you can.... power up your unit using the DC feed spade terminals and limit the bench power suply to about 400mA at 24v..... see if it power up OK..... this way you will know if the fault is in the audio circuit or power supply circuit.
Also check that the case of teh 2N3055 isn't shorted to the analogue ground plane..... the screw pad is only just big enough for the shakeproof washer.
Colin Adshead
www.audiomaintenance.com
Ninuz said:Slenderchap said:That is correct for 220/240v operation..... it should only take about 15mA from the mains so a 100mA Slow Blow should be OK
Colin Adshead
I been putting some time aside to try and get 2 of my units to work but still get blown 100mA fuses.
The 48v rail works fine with the rail connected to the secondary wires from the main trafo as long as I don't have the white 24v cables connected to the PCB.
I got a bench power supply to Feed the 24v tab limiting to 400mA as Colin recommended and then I get the power led glowing.
Feeding the 24v rail I get a current draw of around 100mA without adjusting the BIAS Output.
Yesterday I tried connecting Line audio through both units one att a time and both units seems like they work as they should including the EQ section. This was done taking 48v from the main trafo and 24v from the bench supply.
I measured the white cables ( sec trafo ) and get around 27v AC
From this I suppose the problem is somewhere between the main trafo and the 24v tab. Looked for shorts and components placed facing the wrong side but can't find anything wrong there.
Any suggestions anybody? Places to measure or other tips?
Would really like to get them racked up so I can start using them.
Thanks in advance!
