ding
I got the boards and I'm placing the mouser order but there are a few parts I'm doubtful on because of XY reasons.
1. The manual didn't make it very clear although the schematic did but trying to make sure. The switches for the daughter board are DPDT ON-NONE-ON (ON-ON) 2.54mm PCB switches like these?
http://www.mouser.com/Search/ProductDetail.aspx?R=108-2MD1T2B3M2QE-EVXvirtualkey12040000virtualkey108-2MD1T2B3M2QE-EVX
2. The manual made it clear that the HPF was a SPST switch but not the variety. It seems like it should be an ON-OFF-ON but just to be sure. Like the following?
http://www.mouser.com/Search/ProductDetail.aspx?R=2M1-SP3-T1-B1-M1QEvirtualkey69100000virtualkey691-2M1-SP3-T1B1M1QE
3. I will be building a dual unit but I will be building out all the parts on each of the boards (HT and phantom). The manual suggests I should install the CHT cap. Is this correct?
4. Mouser didn't carry the 1000PIV rectifier specified in the manual. Is this one a good replacement?
http://www.mouser.com/Search/ProductDetail.aspx?R=DB107-BPvirtualkey54720000virtualkey833-DB107-BP
Alain
Alain
