you can do an LA2 type mod by playing with different value caps across the feedback resistor, when it is switched in.
it lets more hi freq stuff in as neg feedback, hence, less high end.
in order to get a good low volume sustain without a mesa 400 volt preamp B+ harsh santana "shes not there fizz" then you need a dual master vol after the phase inverter.
you set up your overall volume in clean mode with the master master, which will be close to your overall volume in suatain mode, the first volume knob will bealrady on 11 of course, then you adjust your sustain with the in between master control.
The good part about this is, is that there is less of that transition drama when a guy hits the master switch, if you have a foot pedal brought out.
I hate that when it is blatently obvious when someone switches in some sustain.
It should be a smooth transistion.
The phase inverter master acts more like a limiter, than a volume boost, if you know what I mean, because it limits both clean and dirty signals.
This is as much clean sustain your amp will be capable of, without using an outbord effects pedal.
If you hate changing 9 volt batts and having the wires break, then you will want to use no boxes, and thus one less cord to plug in.\
So if the amp still does not have enough mojo, you have to either add another stage, which is a pain, or tweak the existing stages for more gain.
How do you do that?
Easy with tubes.
Just plug in a 12AX7a in the phase inverter spot for starters, and report back immediately.
Or, get some hotter pickups.
There are some youtube vids of of Edger Winter with Ronnie Montrose doing free ride. if you search a bit.
I swear, everybody was so F'd up back then. The band was messed, but the audience didnt care, becuase then were even more messed up!Deringer, sheesh, his eyes were half closed most of the time.
I wish people had that spirit nowdays.
That VH concert was good, but the audience was dead.
Only one guy got cuffed in the whole place, and they let him go.
that sounds like an "in between out of phase" strat sound, but montrose has alwyas liked the humbuckers.
there is some cool Montrose at winterland from the first album on you tube also.
I put a little 3 in 1 oil on the rosewood before I play that song, you cant hit those chord slides on a sticky neck.
And if you hang up and miss, everybody heres it on that song.
OK, the strat sound is the intro, you are talking about the vibrato sustains.
That is definately a Gibson.
The way he gets that is to excite the string with a shake that is super imposed on the original factory standard Montrose signature slow hand vibrato frequency. Nobody uses that vibrato speed, BTW.
That is how you can tell when Ronnie is playing on anything.
For a vivid lesson on this, see "Town Without Pity"
Crank it, if your spine does not tingle, you are clinically or musically dead.
Don't tell anybody about this trick.
It takes a lot of energy, becuase you are adding energy to the string, which is very tricky to do.
Only a few freaks...
Funny, Ronnie has terible stage fright.
Tghat is why you do not see him out there much.
One time at the Cow Palace at a New Years show with ZZ Top, which is a huge place, the power went out on the opening number three times.
Ronnies hands were shaking so bad, I thought he was going to go into a seizure and collapse.
Funny to see the real people behind the image they put out.
