moamps said:Values in oval frame are AC (audio, 1kHz test tone) and in rectangular are DC.
Yes.sonolink said:I see, so oval values on the schematic are AC readings that should show when applying a 1 kHz test tone with the knobs placed as described on the schematic, right?
That's a test voltage, run at a fraction of the rated power. Used for assessing gain and making sure the amp is not clipping.sonolink said:Oooops.... :-\
Good thing I checked with you first!!
I don't understand why the schematic says TP28 should be 66.5 volts then?
You need high voltage probes, or you can DIY something.I guess my scope won't do then, right?
It's fixed now.sonolink said:Sorry Abbey, when I try to see the pic clicking on it I get this message:
"404 - Attachment Not Found"
Yes, definitely much better than my DIY suggestion.I'm wondering if this probe would work with my scope?
https://www.amazon.co.uk/Kuman-P4100-Universal-100-Oscilloscopes/dp/B019RLWIZ2/ref=sr_1_fkmr0_1?ie=UTF8&qid=1547730206&sr=8-1-fkmr0&keywords=Kuman+Universal+100MHz+Sonda+de+Osciloscopio+Alto+Voltaje+for+Rigol+Atten+Owon+Siglent+P4100
abbey road d enfer said:It's fixed now.
I've never experienced such misfortune. Probably had only high-quality probes.PRR said:I learned (the hard way) these are 500V caps. 10:1 probe, 550V DC, you are AT the cap rating even before you put signal in. ZAP. Probe stops dividing, and the housing may be melted around the trim hole.
If DIY a high voltage divider, keep in mind that many resistors (especially high resistance smaller package ones) do not deliver rated resistance at voltage (check the resistor data sheets for rated voltage) . I discovered this when designing my outlet tester that had to meet insulation specs at 500V. I had to use larger SMD package resistors to meet voltage spec.PRR said:> Please check first the probes you got with the scope. If they have 10:1 or 100:1 attenuation, you can use it safely.
Divider probes have a compensation cap, *series* with the source.
I like Abbey's home-made divider, or a for-purpose High Voltage probe.
