CJ
Thanks1 Happy New Year to you and everybody else!
Nice work on the OT teardown, very few out there.look how close the primary center tap (red) is to the business end of one of the primaries,
which is another good reason to put the secondary leads on the back. you can put more distance between the primary leads also.
they have been doing leas all on one side for years, but lately i have noticed that sometimes things are getting sketch, the pressboard with the staples is the way to go, like they did back when.
vinylglass sleaving works pretty good, high voltage, good for about 5 KV. and more puncture resistant, they call it by different names depending on who makes it, kind of a rubberized fiberglass mesh,
if you are careful you really do not need any extra insulation, just make sure your anchors are good , and a good varnish bake session does not hurt either.
and the build chart which is used to keep an eye on the overall dimensions of the coil as you wind.
numbers are loose in tolerance as measuring is never exact due to varnish buildup and operator error.
Many thanks, will try this on my next build! I have tried to figure out if old Dagnals used interlayer insulation like this. Do you know?yes, layer insl 0.003" Kraft Paper (brown paper they wrap your steaks in) transformer grade probably dried out, maybe treated, or not,
Wow, thanks, that is exactly what i needed! Beers on me if you are in the Manila area some dayToo much varnish has fried my brain. Two cells left and one is flickering.
https://groupdiy.com/threads/marshall-jcm-900-opt-100-watt-dagnall-c3070.57431/
