squarewave said:
And I'm not sure it's necessary anyway because if the board is configured as a mic input with 48V power, pin 1 must be connected to a non-chassis ground for the 48V return current
I believe you did not grasp fully the implications. With phantom power, Pin 1 needs to have a
galvanic connection to the phantom supply reference (0V), but it does not need to be a "stiff" connection; having even a few hundred ohms would still provide perfect phantom operation. But "stiff" RF connection betwxeen Pin I and the power ground and chassis is paramount. Stiff means the impedance of that connection must be very low at RF, so a capacitor with short leads is as good as a short piece of wire. But the impedance at 50/60 Hz must be reasonably low in order to provide good hum rejection, and sufficiently high as to minimize loop currents. Differential ground voltages are usually <1Vrms, so a 100 ohms limits current at about 10 mA.
If it's a line input, ideally pin 1 should just be left unconnected entirely in which case there can be no shield currents.
I beg to differ with the word "ideally". Although leaving Pin 1 unconnected for line level connection may work in "ideal" environments, the need for a proper connection may arise in many circumstances.
I know some people insist it should be connected to chassis ground
Rightly so
so it can be jumpered that way or with the Jensen resistor cap shunt.
The series arrangement of the "Jensen" RC does not provide the needed "very low impedance at RF"; it should be a parallels RC.
Also, the last 3-4 posts have all been about the shield. Meaning pin 1 and the "pin 1 problem". I understand what you're saying and I appreciate the comments. But my original question was about RF filtering the input pins 2 and 3.
Filtering pins 2 & 3 is almost inseparable from the Pin 1 issue, since common-mode noise is referenced to "ground". If you want to filter out the voltage between either pin 2 or 3 and Pin 1, you have to make sure that Pin 1 is a valid reference.
I must say this can be debated, since it's actually the voltage between pins 2 & 3 and
chassis that is the issue, so, yes, pin 1 could be left floating, as long as a proper connection between shield and chassis is provided. Pin "G" may be used as shield connection; as long as all the wiring is done in accordance, why not. This arrangement was advocated years ago by Gotham Audio, who had a specific 3 cond+ shield cable; this was a way of avoiding issues created by the then usual practice of connecting Pin 1 to audio ground. Anyway, whatever name you give it, you must have a connection that carries the shield/chassis/earth equipotential.
It's not clear that that question was every answered
I believe most of them were, but you seem to be too far engaged in your design to seriously reconsider.
a) the shield is probably much more important wrt filtering than pins 2 and 3
As I wrote, it's a matter of voltage difference, so in that respect, all pins have equal importance; when a-b=c, is a more important than b?
b) if there is RF on 2 and 3 it's already too late.
Why "too late"? Assume there's always RF on pins 2 & 3.
The question ultimately becomes, how much attenuation is provided by blocking RF on the leads
That's a good question, and there may be several answers, according to the various environments, but today, most of the issues are with cell phones and industrial noise. I would say most of the pollution is between 1 MHz and 1 GHz, far enough from audio frequencies to make filtering relatively easy.
even though it can still be capacitively coupled to other parts of the circuit.
That's why it is important to keep the parts that cannot be filtered as short and small as possible.
There are plenty of schematics with LC filters in inputs that shunt to ground on a PCB. Can they all be wrong?
Some may be wrong. When the CE regulations came in, many designers did not know exactly how to tackle the issue, so they used parts that sellers told them would solve their problems, but without mentioning that implementation is as important as the filters themselves. But TC electronics, for example, have a perfect implementation of RFI/EMI protection, although built on a PCB.
