Bezen: You are referring to somewhere-near maximum specs of a tube - there's no design requirement that you go to it's limit.
Getter material is flashed at factory, and will catch minute traces of gases over time, even when stored in it's cardboard box - tube operation does not affect this at all.
Lower heater voltage is probably more of a problem - but most tubes are designed for +/-20% tolerance for heater voltage (as it should be able to run on batteries). Some cathode materials are more sensitive to massive underheating than others - I have VF14's in u47's running on 50'es year on 50% heater voltage, but experimenting with EF40's in this range has shown as little as 20-30hours of operation before problems arise.
Dmp: take a look at 12AY7-based amplifiers, note grid resistance range.
Jakob E.
Jakob E.
