bxt403
;D
I have to make a comment about JLM's wiring diagrams (which I ignored and went with Mr. Forssell's recommendations as found below):
http://www.groupdiy.com/index.php?topic=5374.0
As mentioned elsewheres - the 110, unlike the 101 (which I suspect the JLM diagrams are mislabelled to be 110) requires a dual rail of 24 volts DC (i.e. + and - 24 volts are required, NOT a single +24V; which is for the 101).
I found some Triad HS-66's and A67-J's...keeping consistent with the 110's 600 ohm input impedance the A67-J is wired 600:600, rather than 150:600.
Five Fish Studios 2448 power supply is internal to the case of the 110, and there ain't no issues regarding noise.
I wired a 12 position Grayhill switch to adjust from 40dB to 51dB, and have a hand-wired -20dB pad switch (that is pre-trafo)- but GAIN adjusting can now be made from 20dB to 51dB- and the turning the GAIN switch has a subtle "click" rather than the "pop" I've read about (likely from smaller gain increments from 40dB to 51dB).
I have three SS110 cards- and all had 2 x 250 uF caps (contrary to the recommended 200uf and 250uf)- since one was purchased from a different seller- I decided to stick with 2 x 250 uF caps and haven't had any issues. TVA/Atom series from Vishay/Sprague (I used 25 volt, although some of the cards I have are using 6V, 16V, and 35V).
Also, I think Five Fish Studios MIGHT have the LED wiring backwards in the assembly instructions for the 2448, like with the 1848 I used for my MAP/Melcor rack-job, the reverse wiring for the LEDs worked (and the position that's in the instructions causes no light).
Alls well with this build, now... and I'm lovin' the Spectra Sonics sound, yo!
8)
8)
