I'm looking to get some pcbs made. It would be a small section of a larger build that is originally on a breakaway board, but the way I want to mount it requires some sort of standoffs, for which the original doesn't have holes (or any other mounting options, so why put it on a breakaway board...? But I digress). I also want to change one or two of the footprints, which will not affect nearby components in this case. So I'm basically recreating a bit of an existing board to fit my build layout better.
It seems to me that the best way to do this is to simply get the pcbs made by one of the common services that I see folks here using. The problem is, I have zero knowledge of how tocreate a Gerber file use pcb design software. However, like many who get into DIY, I'm more than happy to invest some time in learning. So my question is, is there a good and (relatively) simple software out there for a beginner to work with -- ideally one that isn't terribly expensive since I'm really just dipping my toe in the water for the first time and have no idea if this will be something I do routinely? Oh, and since it probably matters, I am on a Mac.
Thanks in advance for any suggestions!
