skipwave
Title says it all. Trying to figure how to lash an opto comp onto the output of a BabyAnimal mic amp for a simple gig bag on-the-go recording channel. Since the output is electronically balanced, it seems desirable to use a U-pad with the vactrol's LDR as the shunt R.Schematic of BabyAnimal with 2604 (PDF)
Looking at the datasheet for the VTL5C2, the actual resistance of the LDR will be somewhere between 2k5 and 100k in practical use. With series Rs of 5k, this should net 14dB gain reduction when the LDR is at 2k5, and 6dB at 10k.VTL5C2 Datasheet
That sounds useful to me, but perhaps the output impedance will be an issue? Only needs to drive ADCs with 10k or 20k inputs. It shouldn't stray much over 10k with the LDR up at 100k, and lower with any amount of compression happening. Maybe I should just make it an H-Pad to keep the Z-out constant.
I welcome and appreciate any input!
Brian
Brian
