THAT1512 / Transformer 'blind test' mic preamp
@DaveDC Just double checked and yes, cathode is connected to the +48V output. The 0.17V between the output and adjust pins is very strange, and I don't understand where R6 is sourcing all it current from. It should only have 2mA through it, not 30.
@DaveDC I removed the regulator entirely, along with R5, D6, D5 and R6, so that the only thing connected to the +48V output was C12 and still measured +55V on the output, which had me completely baffled. I then removed C12 and measured 0V. I then reconnected the other components, including the regulator, but with C12 removed, and still measured 85V on the output.
Perhaps the regulator is fried and is passing the full voltage to both the output and adjust pins. That 85V could then have destroyed C12, which is only rated at 63V. I still don't understand how I'm measuring 55V with the regulator disconnected, though.
The transformer has dual 18V secondaries.
@DaveDC Okay, I've removed the regulator again and it turns out there's a dead short between the input and adjust pins, so the full unregulated voltage is ending up at the adjust pin. It looks like the regulator is fried, I think! Still not sure about that 55V reading with it removed, though.
