nrgrecording
[quote author="kato"]Hey I downloaded the .fpd files for the 1176 from NRGrecording.
What meter and case will fit with this panel?
The meter listed at NRG (a hoyt meter) is crossed out - as though it's incorrect.[/quote]
Hi Kato.
There are two versions of 1176 panels.. the G1176 and an original looking 1176... Which do you mean?
Both have the panel cutout for a sifam al29wf. (www.sifam.co.uk) But you can use any meter you want of course... !?
(If you don't know how to change the meter cutout... or you can't use the program (because of mac computer) i can change the panel to your requirement if you want)
I don't know which panel will fit because these are the standard holes from schaeffer. I used panels which already have the 19" holes and the case holes so i just removed the holes...
Is your 1176 working yet and you only need a case?
Regards,
Frank.
Hi Kato.
Regards,
Frank.
