mylesgm
I'll take the knob pack!
Curtis said:Massive Passive and Get Active packs are on hold pending sale.
Cyril - pack 7 has generated a fair bit of interest and will likely sell before too long. Fergusson power transformer is still available though
If you're interested in Pack 4, here's a brief rundown of its contents:
- Approx 100 grey/green push-on knobs for spline shaft pots
- Small collection of setscrew and spline shaft knobs of various sizes (look the same as knobs used on Joe Meek products)
- 9 setscrew knobs, similar in appearance to knobs used on Marshall amps but with a silver face instead of gold
- Large quantity (60+) of 16mm pots with spline shafts of various values (dual gang 20k lin, single gang 50k log, 5k lin)
- Small quantity (10+) of 16mm pots with 1/4" D shafts of various values (500k log, 250k log, 1M log, 100k lin, 250k lin)
- Large quantity of E96 series resistors of various values, 1% tolerance, approx 50 pieces per value
- 2 backlit VU meters 90mm x 65mm x 40mm (note: not true VU meters, but can be made to work with some circuit tweaking)
- Approx 15 push-on/push off latching DPDT switches
- 7 push on/push-off latching 4PDT switches with LED illuminated buttons
- 18 NE5534 opamps
- Approx 10 footswitch actuators (just the mechanism, designed to operate a PCB-mount tactile switch)
- 12 Meder reed relays in a SIL package
Shipping is based on weight and is likely to be quite pricey. I'd need to find a suitable carton for pack 4 plus the transformer, but will probably be in excess of $100AU.
PM me if you want to pursue this further.
