FS: Power Supply - Soundcraft CPS150 - Bipolar 1.25A w/48V
outoftune
canada
Selling a Soundcraft CPS150 power supply.
This is a +/- 17 w/48v Phantom. 1.25A available via LM338K 5A Regulators. Schematic is here: https://www.gearslutz.com/board/attachments/geekslutz-forum/222844d1299085834-soundcraft-spirit-studio-cps150-repair-question-cps150.jpg
All voltages are measuring correctly. You can adjust the +/- up or down to suit your application if it's not a Soundcraft Mixer.
The original power supply cable has been cut. Depending on your application, you could put a replacement cable, or you could also add a multipin XLR to the case. (I can potentially do this for you if you wish).
This unit would make a great bench supply or for powering a 500 series rack.
$200 USD plus shipping or best offer. No Trades
outoftune said:
I'm not sure of the exact current output but it's built with LM338K 5A Regulators.
From the CPS150 manual:
DC VOLTAGE RAILS
+17V      1.25 Amps maximum  output current
-17V   1.25 Amps maximum output current
+48V      0.125 Amps maximum output current
