I use the generic rule of thumb for CMRR with component match of CMRR=20*LOG(Tolerance)... 0.1% would be 60dB CMRR for the 10k balanced line resistors...
However, 0.01% tolerance resistors are available for sub dollar each... cheap.... Bummer is that one has to purchase 1000 units to get the price...
They are also film and not metal, so current induced noise performance would be "compromised", but one might ask, how much current goes through a 10k resistor with, say, worst case 15V on the input to make current noise an issue when kRT noise from 10k may be dominant at temperature? Or with lesser currents under normal operating currents with nominal voltages? Yes, one can purchase Vishay foil resistors (or foil resistance 3-pin ratios) too for reduced current noise, for tens of dollars each, which may not be out of the question depending on needs of the design.... Have fun with a surround sound attenuator for 22.2 or 23.1
Optionally, and as an exercise in lunacy, 0.01% tolerance parts can be further hand matched to 0.001% (100dB CMRR!?!?! but actually slightly less with the hypothetical mismatch build out resistances in the design calculations here; and it is probably closer to 93dB with resistors in series and 0.001% tolerance)... Should take about 21 bins for the binning operation to match to 0.1 Ohm (0.001% for 10k)
This would involve a mini metrology lab; not out of the question for DIY, but could take time and a little cash to implement.... A mini oven would be a bonus to check ppm temperature drift...
of course, it is not the actual value that matters... rather it is the ratio of the values in the match that matter and the newer 0.001% match would be superb especially when sets of input resistors or feedback resistors are all pulled from the same bin (regardless of which bin it may be) when stuffing the board... it would certainly preclude the need for trimmers... Trimmers of course may have 200ppm/C drift (or even 100ppm) too, so calibration on the bench with the box open may have a different operating temperature than when in service, in the rack... I have found by design calculations that 5ppm is really good; 100 ppm is abysmal over temperature range.... Of course if one limited the temperature range of operation in the specs, then it would be fine... say if the range were 1 to 2 degrees
There are some other long-term stability and resistor mechanical issues that also are proposed for implementation in this design to maintain specs over time....
I wonder of commercial units that purport 100dB of CMRR and trimmers and the need to tweak some of them once a year or so... well.... I also think they may use the Birt of the BBC circuit .... just a guess from verbiage in the manual and a rough PCB outline in an older version of said manual highlighting trimmer positions and functions although I have never seen one of their boxes in person.... The Birt of the BBC circuit, I have not analyzed for CMRR fun and recreational math yet... it is sort of a hybrid between balanced and unbalanced.... Really cool concept/circuit in reality....
Meow... I may have let the kitty out of the bag....
Sent from my iPun
