synnys
no, what harpo said is right. its a 4700uf 25v electrolytic cap
mitsos said:If it's only the high boost that doesn't work (but the rest of the controls work perfectly???) that points to a problem between the wiper of your hiboost pot, the inductor(s), the hiboost caps and the BW pot. These are all in series, if there is a break somewhere in this series circuit, there is no high boost. Could be a bad component (but looks like you replaced everything?), miswired pot, broken wire, bad solder joint somewhere, anything. You could try injecting a (music not tone) signal to the input, turn the high boost halfway up and probe along the above-mentioned parts until you find where the signal stops.
Take a look at the schematic, a simplified way to look at it is as if the "hi boosted" signal travels from the wiper of the high boost pot through the LC circuit, through the Bandwidth pot back to the rest of the circuit.
good luck
Maybe assume it is not.synnys said:...and mine is absolutely wired correctly.
4 10k lin
gyraf said:No simple answer. Try to see what works best in your case.
As always, interfacing to an unbalanced input depends on whether the previous stage is electronically or transformer balanced.
But you should connect xlrpin1 to ground in any case.
Jakob E.
