Harpo
Did you try to Google for 'ECC88 datasheet' ?fatheaddrummer said:..I'm talking about ECC88 Tubes. In the schematic there are two of them, but the PCB layout just has space for one...
dipfrik said:Finished two of them over holidays. What a nice sounding and easy build!
Need to A-B-C'ing them against the "B" a Drip V2 and the "C" a Recproaudio Kit (PTP pain 8))
Cheers, Sven
Cheers, Sven
gyraf said:What gain do you have in BA283?
for 30VAC transformer, your storage electrolytic will need to be 50V (or at least over 42.5V)
You don't want to connect the rectifier the way shown (shorting out the transformer).berkleystudios said:proposed schematic with modded power supply
Harpo said:You don't want to connect the rectifier the way shown (shorting out the transformer).berkleystudios said:proposed schematic with modded power supply
The (too high) 30V transformer secondary is AC voltage that gets rectified to 30V*SQRT(2), ignoring the voltage drop in the rectifier giving out a 42.43VDC pk. AC mains voltage isn't a constant and might vary by +/-10% depending on location or time of day and the transformer secondary side will follow with same variation%. The 30VAC is the transformers secondary voltage at rated load and will be higher unloaded (lookup the regulation % at your transformers datasheet, maybe 15%). If AC mains is high and no load connected, this 42.43VDC pk might rise up to 42.43*1.1*1.15=53.67VDC pk and the cap between rectifier and voltage regulator has to be rated for at least this voltage. For a regulated 24VDC out, a 24VAC transformer secondary will leave enough headroom above the voltage regulators dropout voltage in a 10% low mains scenario, only requires 50V rated caps and keeps it way cooler as the differential voltage between input and output of your voltage regulator times current drawn is transfered to heat. Depending on gain/level and connected load impedance of the following piece of gear, a single BA283 may consume up to 150mA of DC power. Your PSU uses a full wave bridge rectifier (form factor K=1.8 ), so the transformer will need at least a VA rating of ((24V*0.15A DC consumption)+1.82W vreg.dissipation+~2W rectifier dissipation)*form factor 1.8=12.8VA. Good luck.
Harpo said:Describes the efficiency of AC current/DC current ratio of the type of rectification used (full wave bridge, full wave bridge with center tap, full wave with center tap, full wave center tap with choke, halfwave, ...) as a result of the different current waveforms.
some simple explanation at http://www.amveco.com/Technical_Notes_3.htm
a little more in depth at http://www.visionics.a.se/html/curriculum/Experiments/FW%20Rectifier/Full%20Wave%20Rectifier1.html
