frazzman said:Hi all,
I've had one of my pultecs sitting on the shelf a while, I always thought it sounded "good" but never "great". Today I put it under the microscope and noticed in RMAA that there was a wide +3db sub bass boost ~25hz going on both with all knobs zero'd AND in bypass.
Any ideas where to look, possible wrong component ? Aside from this all else is well, no noise and all freq positions work fine... Appreciate any insight
jwhmca said:With the EQ "IN" and all the controls down... I'm getting about 1db signal loss? This is normal?
naths101 said:Hi guys,
I'm getting conflicting information everywhere I look... For the power switch, is it SPST, SPDT or DPDT??
Cheers!!
Majestic12 said:You can use either SPST, SPDT, DPST or DPDT. But DPST would be best.
weiss said:hey guys. i wanted to know, how i need to wire a 4 pole pot (e.g. something like this: http://de.mouser.com/Search/ProductDetail.aspx?R=CK2375virtualkey12200000virtualkey10WA177) to swith the pultec on and off?
this is how my frontpanel looks
okay so i need to buy a new oneHarpo said:Something like this switch with 45° indexing for switching mains voltage (whatever your mains voltage might be).
(not a pot and you don't need 4 switch poles. Your link shows a Lorlin type rotary switch with 30° indexing, capable of switching 150mA and 6.35mm (not 6mm) spindle diameter)
Please update your profile with your location data.
