TillM
Thanks !
I will check this !
I will check this !
If anyone wants the panel graphic, I have it in Illustrator , just email me.
Hi MateHi All,
Finally got some pix of my Dual G-Pultec !!!
I used the Hammond 261G6 power trans, it has a 250V C.T. @ 130 ma secondary 6.3V @ 2A secondary. I replaced the 3k3 2w resistor with a 33k 5w resistor to bring the rectified 380vdc down to 240vdc. I replaced the LM317 with a TL1086, its a low voltage drop out regulator and a drop in replacement, although Kingston mentioned that just a dropping resistor could be used as after rectification its about 7.8vdc.
The front panel was done at Prodigy Engineering, I think I may have crowded the left side as I wanted to keep as much room as possible between filter boards and power switch. Collin at AML now carries all the pots for this all in 1/4 inch shafts.
I haven't done extensive testing yet, but so far it sounds Fantastic ! - clean, fat, big bottom end ... and Smoooooooth ;D
no hum or buzz or grounding issues - I only have IEC ground to chassis, I have a ground wire in place to connect to pin1 XLR inputs, but haven't tried it yet
Here is a link to some pix - Dual G-Pultec
All questions / comments welcome
Big THANKS to Jakob E. / Gyraf , Kingston , snipsnip , benlindell , and to this great forum.
Hi Mike !Hi Mate
Mike from Melbourne. Australia.
An amazing build you have done there. Love the pics, and the Hammond power tranny...!!!
I am starting my build soon and love your 2U layout.
Am very interested in your panel graphic, if it's possible.
Once again great dual stereo build...!!!
Mike
Hi Chip,Hi Mike !
No problem on the file ( I just have to find the the drive I stored them on ) LOL Thanks for the kind words , although the pics came out nice , in use they are a little thin , the laser engraving didn’t have a lot of contrast ( dark grey on light grey ) so you might want to change the font to something a little bolder if you are laser engraving. Just PM me an email address to send it to.
please post of your progress and pics when done !
Chip
Ok im going to try that
i read something about using only one DC power supply. is it just to remove the AC cables and connect the 250v DC and 6.3v DC to the "slave card"?
Thank you! That didn’t show up on my web search.
