kazper
EHOFFA007 said:Getting a Bom together for my 2x single Gpultecs.
Just want to make sure these power traffo's will be ok.
http://www.mouser.com/Search/ProductDetail.aspx?R=VPT24-1040virtualkey55310000virtualkey553-VPT24-1040
24.0V CT @ 1.04A 12V @ 2.08A Parallel
Power Rating: 25 VA
Primary Voltage Rating: 115 V to 230 V
Secondary Voltage Rating: 12 V to 24 V
On the Gyraf PDF it calls for 12v 1.5A.
I used Antek transformers (www.antekinc.com)
AN-0512 (50VA) + AN-0212 (25VA)
The 50VA is the first transformer that feeds the heater, and the 25VA is used on the step up.
So your $24 per unit in transformers this route.
You may also look at there new AS-0512 as a alternative for $3.50 more.
The units I built are surprisingly dead quite with the IEC grounded to the chassis.
Kaz
