scott_humphrey
audiophreak said:Hi All,
Finally got some pix of my Dual G-Pultec !!!
I used the Hammond 261G6 power trans, it has a 250V C.T. @ 130 ma secondary 6.3V @ 2A secondary. I replaced the 3k3 2w resistor with a 33k 5w resistor to bring the rectified 380vdc down to 240vdc. I replaced the LM317 with a TL1086, its a low voltage drop out regulator and a drop in replacement, although Kingston mentioned that just a dropping resistor could be used as after rectification its about 7.8vdc.
The front panel was done at Prodigy Engineering, I think I may have crowded the left side as I wanted to keep as much room as possible between filter boards and power switch. Collin at AML now carries all the pots for this all in 1/4 inch shafts.
I haven't done extensive testing yet, but so far it sounds Fantastic ! - clean, fat, big bottom end ... and Smoooooooth ;D
no hum or buzz or grounding issues - I only have IEC ground to chassis, I have a ground wire in place to connect to pin1 XLR inputs, but haven't tried it yet
Here is a link to some pix - http://picasaweb.google.com/audiophreeek/DualGPultec?feat=directlink
If anyone wants the panel graphic, I have it in Illustrator , just email me.
All questions / comments welcome
Big THANKS to Jakob E. / Gyraf , Kingston , snipsnip , benlindell , and to this great forum.
She's a real beaut, Clark!
