Peter Simonsen
[quote author="matthias"]@ CJ:
I want to use the G9 to makeup the gain of my pair of passive pultecs..
if I process some drums or bass guitar I really need some bass
at 50hz the loss is at -4,5db ... no good for that purpose..[/quote]
Not that I do not agree with you regarding this.. a -4.5 db at 50 hz can be bad, but it depends on so many other factors of the signal itself and the total signal chain! and what you´re trying to do to the sound. I have more than once had to insert a 12dboct lowcut filter at 100hz or more (up) on both bass guitar and bass drum...due to not so great tracking ;-)...or other choices made...
Like I said before..how does the unit sound to your ears...??? did you at any point before seeing the missing lowend responce...miss lowend in your use of the pre ???..How does the pre sound/work in your studio ?? are peple satisfied with the sound they are getting ???
Maybe the designer can put some light on this...Is the freq responce as it where designed, or is something wrong jakob ???
Kind regards
Peter
Kind regards
Peter
