G9(and other mic/inst pre) mods
WJS
NJ
anyone have any favorite mods for the g9? or any other preamps?
This is the schematic I used for my last project(my drawing software desided to lose the triode symbol I had made, but i'm sure you can figure it out.
this is a very simplified version, as it only had to run a guitar signal.
has anyone else played with the g9? (i'm sure you have) what did you do with it?
I've done quite a few modifications to the G9 - after all, the DIY-version is based on the rev#16 or so of the commercial model :razz:
What sort of modification are you looking for? To acheive what? Or are you just looking for a modificitation for the mod's own sake?
Jakob E.
If you just need to mod :wink: :
add a HiZ buffer before the inputTX, (wasn't it the Jensen AS004.pdf that would be suited ?).
It could be interesting to compare the sound of the post-inpTX DI-input vs a DI/HiZ-input including the inputTX.
Regards,
Peter
ThanksJakob for catching this one - my suggestion based on..., well, there's no G9 around here - and you've actually tried it, so that's way more useful info.
Just curious, what kind of issues did you run into ?
I must add I haven't build the Jensen-circuit 'as is'; among others I replaced R9 with a current source (coming from a negative voltage).
And powered it from a 'normal supply' (didn't use P48), but that's less relevant for now.
http://www.jensentransformers.com/as/as004.pdf
Regards,
Peter
I was just thinking the could be a place to bounce ideas/results of changes
although rev 16 gives the impresion that its been done.
Yep, ideas about changes would obviously be interesting to discuss, but you need to be specific about what and why you want changed..
Jakob E.
I dont have anything i want changed, i just wanted to know if there were any popular changes. i'm brining the pre i made to its first real session in the next few weeks so i might have some ideas of things i want then but i'm rather happy with what i've gotten. (even if it is only half of the real thing)
