I'd like to record a brass instrument, and my current cheap Amazon mic peaks very harshly when I play it even somewhat close, and at a quiet volume.
I'm guilty of not reading the whole thread in detail ... but Technotech's comment in his original thread tells me his problem isn't gain staging in the interface but the mike itself overloading.Reading the entire thread, I worry you have your cart before your horse, seeking a solution without clearly defining the problem.
.... While I am NOT a qualified recording engineer, I suspect this may be more a matter of proper gain staging than using the wrong microphone or audio interface.
Oddly, this is more expensive than Amazon. The CM-63 listing you posted is also unfortunately out of stock. I've found another that's the same price though.
Interesting. I don't think there's much to work with in the current mic though, so I think either way, I need to buy a new one to record non-vocals.I'm guilty of not reading the whole thread in detail ... but Technotech's comment in his original thread tells me his problem isn't gain staging in the interface but the mike itself overloading.
Hi @ricardo - which circuit and headbasket would be your preference to pair with a TSB 2555 or 140/160?I'm guilty of not reading the whole thread in detail ... but Technotech's comment in his original thread tells me his problem isn't gain staging in the interface but the mike itself overloading.
If that is the case, swapping the capsule for a 'better', larger, louder capsule like TSB 2555 is likely to make his problem worse ... though the sound at lower levels would be improved.
The 'cure' is to reduce the gain INSIDE the mike itself. Some circuits cannot reduce gain below a set limit so you might have to reduce the signal from the capsule itself .. eg by putting a small capacitor across a capsule if it doesn't have a built in FET.
If the capsule has a built in FET, things are more complicated. You would need to modify the circuit so the FET operates as a Source Follower (the infamous Linkwitz mod) or better still ...
turn it into a Charge Amp type circuit. I've got details of details of how to do this in simpleP48.pdf. But not every (??) capsule is easy to modify unless you are a brain surgeon
Incidentally, though I designed microphones for a living in da late 70s & early 80s, I probably haven't listened to as many capsules as k brown.This Millenium, I like the cheapo JLI/TSB 140 & 160 capsules (as well as TSB 2555 of course). Properly mounted & in suitable circuits, they outperform some famous big name German SDCs
It might be easier to use TSB 140/160 (no FETs) and stick your own FET on the back which you can configure as a Charge Amp.
I would choose the simplest solution which is on page 10/11 of SimpleP48.pdfwhich circuit and headbasket would be your preference to pair with a TSB 2555 or 140/160?
Good Day Mr. @ricardo !!I'm guilty of not reading the whole thread in detail ... but Technotech's comment in his original thread tells me his problem isn't gain staging in the interface but the mike itself overloading.
That may well be true ...I still think it COULD be a gain staging type thing - Here is the pitch:
I believe he has a USB microphone
.... loadsa good stuff
Does this not make sense? James
Yes, it's a USB microphone. I hadn't considered the Windows microphone level settings, I thought it was just the mic peaking. I'll try it out, although I suspect the frequency response of this mic will be all over the place. Wonder if I can test it..?I believe he has a USB microphone. One can adjust its output signal level in the Windows System Sound settings.
That's what I thought, but I don't have any experience to know if this is what's happening here.But from the usual cheapo circuits for electrets with built in FETs, I'd expect the FET to overload on a brass instrument "even somewhat close and at a quiet volume."
grab that solo and the cm25. you can swap out that capsule on the cm25 with the 2555 or equivalent you were looking at very easily That's not a bad starting point.Ebay is only showing mounts/stands for those for some reason. I’m wary of Facebook Marketplace, but I have spotted a Scarlett Solo + Scarlett Studio CM25 for a good price (both are >5 years old). Is the stock CM25 any good, or would be better (or even possible) to change the capsule out (without buying a new PCB for the inside of the mic)?
+1I am a huge fan of "multiple causation," it is possible there is more than one thing going on here. Far too often, folks will focus on one aspect and claim "Aha! THAT is THE reason for x" - and another will focus on some other aspect, and claim, "No, THIS is THE reason ..." - yet, in many cases, the problem is the result of multiple, perhaps several, factors which TOGETHER constitute the reason for x. Your comment reminds me of this phenomenon, and look for multiple causes.
Sidebar -
In another realm, I am working with an electrical engineer who claims a particular problem is caused by ... yep, the proverbial "ground loop." Unfortunately, he cannot explain or advise just where the dag blamed "loop" is ... and under the circumstances, it MIGHT be a ground loop among common DC power supply runs, or in mixed audio runs between various devices including a transceiver, computer, small USB-analog mixer, amplified speaker, and other gizmos on a common DC power supply ... so, yeah, "ground loop" ... but WHERE? Again a mystery which may have multiple causes. There may be more than one loop to find and fix. Or we are on the wrong trail entirely.
