[quote author="Purusha"]Since this pre is so popular I wonder if anyone here did some A/B tests VS some high-end BIG NAME PRE? It would be nice to hear it next to a VOX BOX or something.[/quote]
I've heard a shoot-out between a Wunder PEQ1 and a G9 with OEP's in it. It was a simple test with the gain switch in "just" one position. The result was almost a tie. They sounded VERY similar with the little difference being that the G9 compressed the signal ever so slightly and the Wunder being very very "open" sounding. I wasn't really be able to pick a winner because I believe the difference is actually due to the fact that tyhe Wunder is solid state where the G9 is a tube circuit. They both sound absolutely amazing. If a diy interested guy would like to build himself an excellent preamp I can't think of a single reason not to go for the G9. It's top notch, world class, sits comfortably next to the rest of the best, and so on... Furthermore it's not "only" a preamp. It has an absolutely brilliant DI feature. Until I heard the G9 DI my favorite was a Manley Tube DI which already sounds amazing. Full and rich is the first two words that comes to mind... It has a tube and a tranny and in it's "Full" mode it's really unbeatable on a bass guitar....well, it WAS. :wink: The G9 takes it one step further. The G9 lets you saturate the tube differently over it's various gainpositions and you benifit from that when you use it as a DI as well. You know the annoying click sounds that you can often get from bass players muting strings while playing. Well, the G9 gives you a good deal of control over that phenomenon when you saturate the tubes they will shave off those peaks of the waveform while still maintaining a full a fat sound. You can really work the tubes with this baby. I'm absolutely in love with it. A stroke of genious on Jakob's part. Again! And then he went and made it a diy project..... Somebody pinch me, please!! :shock:
EDIT: I have a Beyer Dynamic input trafo and an OEP output trafo in mine by the way. I think the Beyer Trafo is just slightly more "crispy". Suits me fine. :grin:
