JW
I was experimenting with a channel in my console in order to add a volume control to 'juice up' the first opamp a bit and have the opportunity to pull it down with the fader.
First, this is for a 'line in' scenario. I don't believe API used to control the gain of the first opamp with an external control ? except when in 'mic' mode. In this case (312 mic pre) we have a 20K pot switched in to the negative opamps input.
My question is, why can't I do that in line mode as well? In line mode, the signal is fed through 10K resistors (no transformer) to the +/- opamp ins. Yet, the same spot that controls the opamp gain in mic mode seems to do nothing in 'line' mode. I'm changing the 200 ohm resistor in front of the negative input out for a pot. I've tried up to 25K. Regardless, no gain change.
Here's a link to Boji's redraw of the schematic. Console signal flow, input cards, general discussion on API styled DIY mixer
