The input on this remote amp/preamp is "AI-10379" which I found in another part of a catalog as AI-10379T.
yeah the T is for Triad. Similar clues for other manufacturers in the 1960’s.
this is a later 134 with the small input.
emmr: Change the negative feedback resistor to lower the max gain. These are way looser on NFB than the console versions.
When measuring current, you have to put the meter *in series* with the resistor.With the transformer primary path jumpered, R14 is reading 6.97 VDC @ 31.4 mA.
The straight B+ that would hit the transformer is 221 VDC.
This is all with the modified NFB resistor (R11) at 62K. Altough I dont think that would affect this part of the circuit.
Weirdly, when I went to measure the mA of the B+ line, my meter probe would pop/arc. Only tried it twice. Why would that happen? What am I missing? Is my meter not capable of that level of current?
You are effectively shorting the cathode to ground, hence the spark!
trying to figure out magnetic flux for this transformer,
for that we need volts, but all they give us is 25 dBm, some primitive spec that means nothing to my small mind. i mean i have two brain cells left, and one of them is flickering.
we can google a formula, like
Power = P ref x 10 ^(dBm/10)
Pref is 1milli-watt, or 0.001 watts
dBm is given as 25dBm,
Power=0.001 x 10^(25/10) = 0.001 x 10^2.5 = 0.001 x 316 = 0.316 Watts
power in = power out, so 0.316 watts and 12 K Ohms is what?
brute force- Power = I^2 R
0.316 = I^2 x 12,000 , I^2 = 0.316/12,000 = 0.00513 A or about 5 mils primary current
V=IR so Primary Voltage = .005 x 12,000 =
61.6 Volts RMS-Primary
so secondary volts is what? divide by turns ratio which is 4.5, 61.6/4.5=
13.7 Volts RMS-Secondary
we now have volts, and we know how many turns of pri and sec wire, so we are set.
extra credit points, what is secondary current? use turns ratio but be careful.
stepdown xfmr, volts go down, current goes up, because power has to be the same,
so 4.5 x 5 ma = 22.5 ma secondary current.
pretty hefty transformer me thinks, 13.7 line voltage? drive a truck. or a long cable.
However, I dont understand this one.Power = P ref x 10 ^(dBm/10)
